motherboard won`t powerdown - K7S8XE+
  • SlashEMc2k
    • Jun 2006
    • 3
    I have had my pc for about a year now working fine until one day the PC would just not shut down? It reboots fine though?
    So I upgraded my PSU as other strange things were happening like mouse and keyboard stopped working and had read on these forums the PSU would probably be the first thing that needed replacing.
    I have replaced the PSU and now the mouse and keyboard works fine but I still cannot shutdown without switching the PSU off?
    When I switch on the PSU the computer automatically turns on and boots through bios into XP.
    If I press the power off button during the boot through bios or xp the machine freezes. And does not switch off the computer or load any further?? Really strange.
    I have installed a fresh copy of XP just incase, I don`t know why but I just did.. lol.
    I have cleared the CLRCMOS2 a few times and resetup the bios but still have the same problem.
    I presume the problem lies with the capacitors
    I have visually inspected all the electrolytic capacitors and can post pictures but can`t see any bulging or goo comming from any of them..
    Does anyone have a good knowledge of the K7S8XE+ and suggest which capacitor to try and test with a multimete and replace if faulty..
    Any ideas or help would be appreciated
    Machine specs:
    Asrock K7S8XE+ V1.61
    Athlon XP 2000+
    64mb Matrox Millenium G450 Dual Head
    256 MB RAM
    80GB IDE HD
    300 watt PSU
    Windows XP Professional
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: motherboard won`t powerdown - K7S8XE+
    Check if the BIOS has a "power on after power fail" setting, change the setting from whatever it is set to, and then back to "off" or "former status"
    That might fix it, but more probably not
    • MD Willington
      • Sep 2004
      • 702
      Good to see you made it SlashEMc2k...
      Ya'll think us folk from the country's real funny-like, dontcha?
      The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
      • SlashEMc2k
        • Jun 2006
        • 3
        Thanks MD; got to try everything before I throw and replace this MB..
        Tried Setting Restore on AC/Power Loss on and off but made no difference
        • SlashEMc2k
          • Jun 2006
          • 3
          here are images of my caps.
          See can`t see any problems
          image 1
          image 2
          image 3
          image 4
          image 5
          • Shroomie
            • Apr 2006
            • 356
            Well, those OSTs will go bad eventually, but they're some of the better bad caps. Look OK for now though...
            You know there's something wrong when you open up a PSU and are glad to find Teapos.
            Why I don't buy cheap cases!
            • Galvanized
              • Mar 2006
              • 468
              You might want to consider what yanz had to say in this thread.
              https://www.badcaps.net/forum/showth...6808#post16808
              • gonzo0815
                • Feb 2006
                • 1600
                Well, i have a K7s8xe+ too and experineced some other problems. I have recaped the vrm & ram caps, but i think this wasn`t necessary. May be i had to replace those smaler caps, but haven`t done it yet.
                Those small caps aren`t that speccial, any good will work here. For the other caps only super low esr caps are suitable, as the desing of this board is optimized fo lowest possible component count (therefore it maxed out the specs of the best cpas).
                I could immagine, that there is a problem with those smaler caps, which will cause som groundbouncing causing the power on.
                Or there is an switch burnt, leding to a permanent short on the pw switch.
                In any case, before i would do anything, i would test for and short caused by mounting, screws etc. Then chek the pin assginments of the system header, may be there is something wrong(you can power it up by shorting the pw_sw headers). Test wise you can try to unplug the pw switch and look if the issu is gone.
                Additionaly there is an sb power jumper, which will fed the mouse, usb and keybord from the SB line of the psu. may be it will help to disable that.
                To ensure cmose is cleared properly, sometimes it is needed to rmove all power, including the cmos battery.
                This could easily done by removing the whole board from the case and place it on a isolating surface.
                I do this with any system, to make shure it`S the hardware and not something else.
                Then , make shure your new psu is capable to deliver AT LEAST 180w better over 200w combined power on the 5v and 3.3v line.
                And it should be from a respectable manufakturer too. Anything less will for shure only give you haddaches with this board.
                Most new ATX2.0 PSU`S wont power this board for long, as they only have strong 12v rails.
                • Bob_Crachet
                  Some help with troubleshooting a HP ProDesk 400 G2.5 SFF motherboard please
                  by Bob_Crachet
                  I am experiencing the following symptoms:
                  With the device fully assembled when I press the power button, nothing happens at all.
                  I pulled the power supply from the computer and stuck a paperclip into pins 16 and 17 on the connector causing the power supply to turn on and the fans to start spinning. All of the voltages checked out ok.
                  With the power supply outside of the case, I plugged it back into the motherboard and tested it again. No change. PC did not turn on.
                  I put my multimeter in continuity mode and put the black probe on one...
                  05-09-2023, 06:28 PM
                • accepted12
                  Asus G752VT Touchpad cap heated up and smoked, is it fine to keep using motherboard?
                  by accepted12
                  A badly damaged 80C 30V cable for the touchpad heated up a capacitor on the motherboard and it got red and smoked. I tested the touch pad with a different cable and it still worked. Laptop is a Asus ROG G752VT, if anyone has an idea what these caps are I'm willing to reflow some new ones since I have a reflow hot air gun and a little bit of experience. The schematics are next to impossible to find so im not sure what caps would be needed to be replaced.
                  Cable that was damaged and caused voltage spike
                  https://www.amazon.com/gp/aw/d/B09HQ...ct_image_1?smi...
                  02-01-2023, 06:04 AM
                • broke_boi
                  Asrock B450 Pro4 motherboard won't power on.
                  by broke_boi
                  Hello all,
                  (I am just getting into electronics repair so excuse the noobness )
                  I have an Asrock B450 Pro 4 motherboard which doesn't power on. I have access to the Broadview file.
                  I have checked that the PSU is working. I have the 5V standby on pin 9 and the 5V PSON# on pin 16. When I short the pin 16 and the ground I see the fan running and other voltages as well.
                  I have removed everything from the motherboard except the CPU fan and have only connected the 24pin power from the PSU. I have not connected the 12V power from the PSU...
                  09-09-2023, 09:21 PM
                • stanwebber
                  did bad capacitors kill my motherboard or prolonged exposure to faulty psu?
                  by stanwebber
                  i've got a pretty rare motherboard that i'm evaluating for repair. it's a biostar m7mia-raid which is the only ddr socket a motherboard ever produced, consumer or industrial, with an isa slot. its 20 years old now and finally gave up the ghost last month. i was saving a dd image of the hdd to a portable usb drive when i found it unresponsive with a black screen and a solid lit hdd led. after forcing it to power down it never posted again. the psu/cpu/case fans will spin and the onboard motherboard power led will light up, but no beeps or error codes even with the cmos reset and ram plus all expansion...
                  03-10-2022, 12:35 AM
                  ASUS P5GC-MX motherboard recap
                  by momaka
                  Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                  This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                  So here is what the motherboard looked like with its original caps:
                  CPU VRM area up close…...
                  01-27-2021, 11:59 PM
